Will not start
2002 SUZUKI VITARA
120,223 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
MATT N AMANDA SOLARCHICK
I put a timing chain in this car, someone else had already tried to put the chain on and time it, it did not work. so they brought it to me I took the chain off and timed it myself because it was wrong. I am pretty sure it timed right but I have no fire and no codes. It is getting gas. is there a ignition module or a coil somewhere that is keeping it from firing?
Jun 24, 2017 at 9:54 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
We should check compression to see if there is enough to run this will confirm the timing chain being on as well.
There is a crankshaft angle sensor that needs to work as well. (below) This is what signals the computer to work the ignition and fuel injection.
I found the engine wiring diagrams for you well. Use the guide below to test for power at the fuses.
and a timing chain diagram just in case.
https://www.2carpros.com/diagrams/suzuki/vitara/2002
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Jun 26, 2017 at 1:10 PM
GUINESS77
it turns over fine and has good spark but the fuel pump doesn't work so I replaced the pump, strainer, and filter to no avail, no sound from the gas tank at all, there is not a fuse so there must be a relay or two or am I just way off base? any help would be appreciated and if more info is needed please ask.
Jun 6, 2019 at 3:31 PM (Merged)
DAVE H
  • 13,384 POSTS
https://images.2carpros.com/forum/automotive_pictures/266999_suz_19.jpg
UNCANNYMANNY
(Grand Vitara) it is not a power issue. I still have power battery's good, but car cranks over but will not start. sounds like it wants to start sometimes but sounds almost like it does not have enough gas to start. but it has plenty gas all fluids look good. i tried a jump start. i tried giving it a little gas (only tried once not too much).
Jun 6, 2019 at 3:32 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
It sounds like you have either weak fuel pump or a crankshaft angle sensor that is out.
Here is a guide hat will get us started to see if you have spark and fuel pressure:
and
I posted how to remove one of your coil's leave it plugged in put a plug on the end of the boot of it. Ground the plug and crank it over and look for a blue spark. Let's start there then we will check other thing's.
Ignition coil assembly (igniter and ignition coil:
Removal.
1. For H25 engine, remove ignition coil cover.
2. Disconnect ignition coil coupler.
3. Remove ignition coil bolt (1), and then pull out ignition coil assembly (2).
Installation.
Install in reverse order of removal.
Please let us know what happens so it will help others.
Cheers
UNCANNYMANNY
so you want me to remove one of the plugs and put a spark plug on the end of it and put it against a ground?
SATURNTECH9
  • 30,869 POSTS
Yes, unless you have a spare plug somewhere? It does not start so cranking it a few time's without the plug will be okay. Just stand to the side of the engine so you do not get hit by the compression blast.
UNCANNYMANNY
The problem ended up being the crankshaft angle sensor.thanks for your time. this site rocks!
SATURNTECH9
  • 30,869 POSTS
Glad to hear you got it started.
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
NENARUIZ33
Overheated wants to turn but will not start
  • 54,350 POSTS
Depending on how bad it overheated it could have collapsed the piston rings causing low compression.
Here are a couple of guides that will help you.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
Please let us know what you find so it will help others.
Best, Ken
