Mechanics
CAR DOESN'T REACH ABOVE 110 KM / H
2011 Suzuki Other
Hi;
I have a 1995 Suzuki Swift 1000 cc. This car has a strange problem. It never reaches above 110 km /h. Its engine has been overhauled. Clutch has been replaced.
Recently a mechanic removed the distributor bolt and rotated it upwards, according to him the engine sound is much better by advancing the distributor upwards too much, means some thing wrong with timing. Now timing belt is fine. What else could be wrong.
Just to make things more clear the mechanic removed the bolt for distributor adjustment because he want to rotate it even furthur then the bolt allows.
AD
Adil ali
July 21, 2006.
Have the bolt eturned to correct place and check for compression is good
Dave H
May 30, 2010.
AD
