1990 Suzuki Other Repair Question
Topics covered: Compression, Engine, Mechanic.
Asked on November 19, 2008
1990 Other Suzuki Models how to replace lash adjuster.
Engine Mechanical problem
1990 Other Suzuki Models 4 cyl Two Wheel Drive Manual
my engine code g13b, after overhaul have tapping sound and compression not good, how to choose good lash adjuster and solve tapping sound?
Answer
Replied on September 3, 2009
this is first time run on a fresh overhall?
ok.
bad compression. sure that would be normal if lash is wrong and it will be , when the head is put back on.
than set the lash to spec.
I wish you had told car model. and country .
but year 90 helps me,. little.
there are lots of 3 cyl cars by Suzuki.
but g13b , in my country uses.
413 swift?
DOHC or SOHC.
give model of car , answer is easy.
so very easy.
