1991 Camaro RS
NASCAR20
  • 1991 CHEVROLET CAMARO
I drove my car to town one got back in it it would not start. Everything else works fine but it would not start, click, or do anything. I need help getting my car back on the road. I have changed the nutural switch and it did not help any. I can not figure it out nor can my brother inlaw that is a mechanic. HELP! My car has 160, 00 miles with a 5.0 engine.
Monday, January 29th, 2007 AT 3:47 PM
Try clean and tight connections on the battery and starter then go find the fusible links. Okay there start at the ignition switch
BTW when key is in On position -do you see any idiot lites on the panel.
Saturday, August 17th, 2019 AT 5:03 PM
ERVINKING5
  • 2004 SUZUKI FORENZA
Clutch goes all the way to the floor, and wont shift, but will start
Tuesday, March 2nd, 2021 AT 11:04 AM (Merged)
  • 31,938 POSTS
Hi there,
If no pedal pressure, check the clutch fluid level, if low you will have a leak at the master cyl or the slave cylinder, you may be able to get some pedal back by adding fluid, and cracking the bleeder with your foot on the clutch, close bleeder lift pedal and repeat, checking that fluid is not to low after each bleed, this should give you enough clutch to get to a mechanic to get it check over.
Mark (mhpautos)
