1999 Suzuki Baleno Repair Question
Asked on May 6, 2010
1999 Suzuki Baleno Problem in the RPM
Electrical problem
1999 Suzuki Baleno 4 cyl Two Wheel Drive Automatic
Hello to you all
Problem:
Run the car at the beginning of the morning or a cold
Van Meter of the RPM down more than usual about
100-150 rpm and then noticed that
An auto engine down, and continue to do so
For 2 seconds and then begin to rise as the rpm
He enjoined should also be made.
Question if I may:
Is the problem the engine temperature sensor ?
Is The problem The Idle valve ?
Or that there is another problem?
Note:
Been cleaned up thethrottel , but to no avail.
With thanks to you all.
Hello to you all
Problem:
Question if I may:
Note:
