2003 Suzuki Aerio Repair Question
Asked on July 25, 2010
2003 Suzuki Aerio bolts to control arm
Drive Train Axles Bearings problem
2003 Suzuki Aerio 4 cyl Front Wheel Drive Automatic 150000 miles
I have loosened the 17mm bolts to the control arm, one just turns, the other acts as if it is spring loaded. I cannot see or access the other end of the bolts. So if there is a nut on the end, I cannot get to it. The bolt that just turns does so because I heated the knuckle it passes through which softened the rubber bushing enough to allow the bolt to turn. I have also tried prying on the bolt as I turn it.
