1998 Subaru Outback Repair Question
Topics covered: All wheel drive, Coolant, Cooling system.
Asked on November 11, 2010
1998 Subaru Outback bleeding air from cooling system
Engine Cooling problem
1998 Subaru Outback 4 cyl All Wheel Drive Manual 129000 miles
the upper radiator hose recently burst from age. I replaced it and refilled with coolant. It still overheats and there is no heat. it was fine before the hose burst and did not overheat.
Someone told me i need to bleed the air out of the cooling system, How do i do that?
If it's not air in the system , then what else could be causing the problem ? The fans are working fine.
Thanks ! Nate
Thanks ! Nate
