Mechanics
-OIL AROUND SPARK PLUG BOOTS
Subaru Other
Subaru- Oil around spark plug boots
2001 Subaru Outback, 2.5L, 4-cylinder, 79.500 miles
I changed the spark plugs. On three of the 4 cylinders, when I pulled the wire boots out of the plug " tubes" there was motor oil around around the boots and seeping down into the tubes. Only one of the plug boots was completely dry and I see a seal surrounding the tube.
I cleaned all oil from the tubes before replacing the spark plugs. Can I try to tighten down on the valve covers or should I replace the seals? I know that I can't allow the oil to build up around the plugs. Any suggestions? Thank you.
Bugmug
July 4, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
