Overheating
SUBARU
MMCHAMPION
I have a 1990 Subaru Legacy L 4WD. It has started overheating. The Electric Fan will run for afew minutes and then it blows the fuse and stops. What could be causing this to happen?
Jul 15, 2007 at 2:03 AM
WRX246
  • 39 POSTS
i'm not sure if this is the problem or not but try the following
its not going to cost to much to pull the radiator out & get both tanks tested the may be blocked or the radaiator fins themselves may be clogged otherwise there is a wiring fault somewherre
thanks carlisa
Jul 16, 2007 at 8:31 PM
