Mechanics
STEERING
2002 Ford Taurus • 150,000 miles
Sons vehicle made a turn into a shopping ctr on a slightly raised slope. He hears a crunch, felt he got snagged on concrete somehow, smells a burned oil smell, then vehicle starts pulling to one side and making clanking noises when turning the steering wheel. I looked underneath, nothing is hanging or seems broken. Everything I touched seemed attached appropriately. There are no fluids on the ground under the vehicle, or across the path the vehicle traveled when the crunch sound happened. The steering wheel makes a clanking sound every couple of inches turning it either way. It doesn't seem to want to turn one way more than the other but it will and does turn. The wheels are facing in the same directions correctly and the belt is tight. What's wrong with this car and how much is it going to cost me?
Msamples66
May 3, 2013.
I'd bet the son did more than a crunch. Have the fornt end checked locally for a better quote on price they have to see what is wrong with it first.
AD
Hmac300
May 3, 2013.
I checked the car out myself. Did some research. Pretty sure I know whats wrong with it. The cv joint broke. Shouldnt cost too much to fix. Having it towed tonight even though its still driveable. Don't want to make it worse. Thanks. M
Msamples66
May 3, 2013.
They are about $110-150 at an auto parts store if you wan tot do it yourself.
Hmac300
May 3, 2013.
AD
