Mechanics
STARTING/ FUEL ISSUE
1990 Pontiac Grand Am • 139,000 miles
Upon starting the car will start but only run for few seconds. I noticed that when cranking the engine the injector does spray fuel but once it starts the injector does not spray fuel I wired the fuel pump direct and is working but the car still only runs for a few seconds
Biil1978
May 27, 2013.
Scan for codes and check fuel pressure with a gauge it should be 41-47 psi it may have a bad pump.
Hmac300
May 28, 2013.
AD
