Mechanics
SPONGY CLUTCH THAT WILL NOT ALLOW THE TRANSMISSION TO ENGAGE
1997 Ford Ranger • 200,000 miles
I have replaced the clutch, bearings and pressure plate. I also replaced the slave cylinder and the clutch master cylinder. I have done everything that I know to bleed the system to make the clutch stand up so the transmission will engage. Tried bleeding the slave cylinder and the clutch master cylinder but had no success.
Pankjr0
August 28, 2013.
What is bleeding proceedure you used?
Docfixit
Aug 28, 2013.
