Mechanics
SPEED SENSOR HAS NO VOLTS TO THE PLUG FOR SENSOR
1999 Ford Taurus • 3.0L 6 cylinder 2WD Automatic • 98,255 miles
The frist thing I done was I put in a new sensor in it didnt work, then I took one out of a car that did work in the outher taurus. Then that didn, t work, then I put in anouther spedo cluster in the dash that didn.T work.I took out pcm from anouther car same year and that didn, t work. I put the origional back it was the same thing, I changed the black box behined the fuse paneland that didnt work, jim I need to know what supples the green and white striped wire to the sensor. Where does it get it, s volts from and where is it located. And where you pluge in the ubs tester under dash no volts to any pin so I can, t use the obd2 tester
Cuda1965comando
December 10, 2013.
Pin 58 on pcm supplies power to vss that is the positive side first is two pin vss second is three pin vss 58 still were reference signal is from/
Hmac300
Dec 11, 2013.
