Vehicle will not go more than 35 mph then engine revs . Could a faulty knock sensor cause this?
Mar 7, 2019 at 5:55 PM
CAR REPAIR CONTRIBUTOR
Good morning,
No, the knock sensor will not cause this issue.
It does sound like the transmission is not shifting into a higher gear.
How long since you change the oil and filter in the transmission?
Is the check engine light on? If it is, do you know the codes?
Mar 8, 2019 at 4:28 AM
