rear wiper stopped working
2004 SATURN VUE
54,000 MILES
BUSCHMAN
my wife went shopping the rear wiper worked on the way to the store, but did not work when she left.
Mar 10, 2012 at 6:21 PM
  • CAR REPAIR CONTRIBUTOR
See Rear wiper EWD below.
Mar 10, 2012 at 6:29 PM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one have you checked the fuse yet? Also, do you have a multi meter?
Mar 10, 2012 at 6:49 PM
BUSCHMAN
i do not have a DC multi meter. i only saw a relay for the rear wiper in the owners manual and nothing for a fuse.
Mar 10, 2012 at 7:43 PM
SATURNTECH9
  • 30,869 POSTS
Look at the wire diagram that Rastamaz posted, it shows the fuse for it.
Mar 11, 2012 at 7:07 AM
CVANDERSLICE
Six cylinder all wheel drive automatic
The passenger side wiper only will not work. What needs to be done about fixing this?
Jan 13, 2017 at 4:16 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
First thing I would check would be to see if your wiper arm nut was loose.
BILL123
Passenger wiper only decided to stop working. Before bringing it in any ideas on what is wrong as passenger wiper is fine?
SATURNTECH9
  • 30,869 POSTS
So are you saying the passenger wiper does not move back and forth? If that is the case then i would see if the nut holding the arm on loosened up. Or that the splines on the arm or the shaft are not stripped.
HALS
Four cylinder two wheel drive automatic 140,000 miles
In December while drive there was some kind of bad connection in my steering column and it started to smoke. well nothing to bad came of it, just my windshield wipers would have a mind of their own sometimes. Now my windshield wipers do not work at all. my horn does not work, my lock/unlock remote does not work, my front left light is out, and my side mirror adjuster does not work, but i still have the radio and lights. what could possible be wrong and will it cost a lot to fix?
