Engine Performance problem
2002 Saturn Vue Front Wheel Drive Manual 130000 miles
The Check engine light stays on The scanner showed that the O2 sensors were bad. That is the only code that showed. I replaced both sensors. The upstream sensor was a dealer sensor. The downstream sensor was a after market part. No other code shows on the scanner. Each time the garage resets the computer. I drive 75 miles and the check engine light goes on again
Jan 23, 2009 at 7:38 PM
