Mechanics
02' 3.0 WONT STAY RUNNING CYLINDER 3 MI
2002 Saturn Vue
Engine Performance problem
2002 Saturn Vue 6 cyl All Wheel Drive Automatic 120000 miles
I have a 2002 Saturn Vue trouble starting sometimes starts but cant keep it running stalls out. My codes were cylinder 3 misfire and coolant temperature operating below temperature range. I changed the plugs and thermostat and coolant temperature sensor. Still had the problem. I pulled the plugs to do compression check and the new plugs were charred black already. My compression was good. I thought the cat might be blocked because the pipes were getting cherry red. I changed the cat and put new oxygen sensors in and still had problem. I changed the timing belt put 2 new coil packs on and put 2 cans dry gas in and changed fuel filter. Still having problems. Does anyone have suggestions?
433mouse
April 10, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
