1997 Saturn SW1
Engine Mechanical problem
1997 Saturn SW1 4 cyl Front Wheel Drive Automatic 214569 miles
when you get in the car put the key in and turn it on the dash lights are on then when you turn lights on all dash light radio light and shifter lights go out, then when you get out of the car and turn the key off and leave the key in the ignition and turn the light switch off the dah light are vey dim also I noticed that if you turn the turn sigmials on when the key is in the ignition and lights are turned off the fuel pump relay clicks?
December 20, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
