Mechanics
IDLE PROBLEMS
2001 Saturn SL1
Engine Performance problem
2001 Saturn SL1 4 cyl Front Wheel Drive Automatic 85000 miles
MY CAR IDLES TOO HIGH AT STARTING ENGINE THEN LEVELS OUT IN A COUPLE OF MINUTES UNTIL I PUT IT IN GEAR. IT DOESN'T MATTER IF I PUT IT IN REVERSE OR DRIVE, THE ENGINE REVS UP AND GETS UP TO 30-40 MILES AN HOUR WITHOUT EVEN TOUCHING THE ACCELERATOR. AS I DRIVE ON THE ROAD YOU CAN TELL THE ENGINE IS RUNNING A LITTLE TOO HIGH. OTHER THAN THAT THE CAR RUNS FINE. ALSO THE TIMING BELT HAS NEVER BEEN REPLACED COULD THAT BE SOME OF THE PROBLEM? CAN YOU HELP ME?
AD
SNUGGLEBUG
December 10, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
