Mechanics
STARTER
2000 Saturn SL1
2000 Saturn SL1 6 cyl Front Wheel Drive Automatic
my saturn want turn over, put new battery all the instruments turn on when I try to start but nothing happens. Want turnover. Coulditbethe starte and where is it located in 2000 saturn sl1
Mrlefty1115
June 11, 2010.
Yes it could be your starter it's under your intake manifold mounted to the block. You don't have to remove your intake to replace it. Do you have a test light or multimeter so you can trace power to see if it's the starter?
Saturntech9
Jun 11, 2010.
