Fuel pump replacement?
2002 SATURN SC2
120,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMMYV35
i have 2002 saturn sc2 car will start for about 3 seconds then kicks off. i sprayed starting fluid and it will run while being sprayed. fuel pump kicks on . what do you think. i think fuel pump
Mar 6, 2011 at 2:43 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
So does your security light stay on solid or flash while your trying to start it?If so your ecm is disabling your injector pulse.Let me know.
Mar 6, 2011 at 4:08 PM
HMAC300
  • 48,601 POSTS
check your fuel pressure it should be 40-55 psi. if it is your pump then replace your filter as well
Mar 6, 2011 at 4:10 PM
JIMMYV35
security is off while starting. check pressure and had none. won't start at all now. pump still turns on
Mar 6, 2011 at 4:50 PM
JIMMYV35
Also i coded it and P0341 showed up and replaced plugs and wires and voltmeter coils and they were good
Mar 6, 2011 at 4:53 PM
SATURNTECH9
  • 30,869 POSTS
A P0341 won't keep it from starting?So you checked with a fuel pressure gauge and you have no fuel pressure?So you can hear the fuel pump running or the fuel pump relay kick on and off?Let me know.
Mar 6, 2011 at 8:39 PM
MIKE HALACY
how do i change the fuel pump?
Aug 11, 2020 at 6:03 PM (Merged)
Here is a guide to help you step by step with the instruction to replace the fuel pump on your car in the diagrams below.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
KDILDEY
how do I replace the fuel pump in my sc2 and do I have to drop the tank or is there an access under the rear seat or from the trunk?
BLUELIGHTNIN6
  • 16,542 POSTS
Must drop tank.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_261.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_81.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_44.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname4_28.jpg
Thanks for using 2CarPros.com!
MRPAPPA
2001 Saturn SC2 - I filled up car with fuel; drove 3 miles and parked it for the night. Next day I drove 3 miles and turned it off for 1 hour, restarted car but it died 3 seconds later... It will run with starting fluid... I can not find the Fuel Pump Relay under the hood in the fuse panel area.. Where is it? If it is not the problem, then probably fuel pump, right?? Guess I will have to siphon full tank of gas (which I had problem getting gas out)??? Then drop tank because no access panel under rear seat or trunk, right???? Are there other checks you would recommend before dropping the fuel tank?????
BTW - While looking for access panel to fuel pump in trunk, I found a couple gallons of rain water from previous problem with sunroof drain line.. Wonder if there may have been a way for the rain to have shorted out the fuel relay or something else?????
Have a Happy Thanksgiving Tomorrow!!!
Thanks,
Greg
Aug 11, 2020 at 6:04 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
The fuel pump relay is in the inside fuse box and they rarely fail so i doubt its the relay.See if the fuel pump fuse has power to it while cranking if it does the relay and fuse is good.Have you checked the actual fuel pressure?You have the injectors not pulsing or a fuel pump issue.Is the security light on solid or flashing when trying to start it?
WES4321
Engine Mechanical problem
1999 Saturn SC2 4 cyl Front Wheel Drive Automatic
hey guye have a 99 saturn sc2 i am looking for the fuel pump relay and also looking at the fuses i can't tell which one is for fuel pump can you help
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_saturn_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_saturn_2_1.jpg
The database showed the above for the instrument panel junction block.
SUAREZ
how do i replace the fuel pump on a 97 saturn sc2
SATURNTECH9
  • 30,869 POSTS
You have to drop the gas tank pretty easy on that car you just have to get the rear of the car up high to clear the tank straps from hitting the ground.Whats wrong with the pump is it bleeding down on that car pretty common for that year.
DRUIN
My wife drove her car with no problems yesterday. Today it won't start. It's acting like it's not getting fuel, but I can hear the fuel pump coming on. any ideas?
BMRFIXIT
  • 19,053 POSTS
check for spark
check for codes
check fuel pressure
is it due for tune up !
check fuses
SATURNTECH9
  • 30,869 POSTS
So you have a crank no start?Without checking the pressure we dont know if you habe the correct fuel pressure to start and run.Lets try this hold the gas pedal all the way to the floor while trying to start it see if it starts.Sounds like it could be a bad coolant temp sensor and possibly corroded connector.
SIERRASMOMMY07
Interior problem
1994 Saturn SC2 4 cyl Automatic
I have a 1994 Saturn SC2 and i was trying to figure out what the box thing is called that's located under the console. I know it has to do with the fuel pump but im not sure what it is called. If someone could please tell me I would greatly appreciate it. Thanx so much.
BLUELIGHTNIN6
  • 16,542 POSTS
diagram below show it?
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_395.jpg
SIERRASMOMMY07
Yep. I think thats it. Thanx so much for your help.
IMSNYDE
I would like to know to. But it under the center console by the e brake. thanks
LARRAMORE8
How do you replace the fuel pump
Removal Of Sender From Fuel Pump Module.
https://images.2carpros.com/forum/automotive_pictures/12900_fps1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_fps2_1.jpg
REMOVAL WARNING: * Do not allow smoking or the use of open flames in the area where work on the fuel system is taking place . * Anytime the fuel system is being worked on, disconnect the negative battery cable, except for those tests where battery voltage is required . 1. Remove fuel tank, refer to Fuel Tank / Service and Repair . 2. Remove fuel pump module, refer to Fuel Tank Unit / Service and Repair . 3. Remove the two sending unit electrical connections with needle nose pliers or by pressing down the locking tab and pulling connector off the terminal. 3. Using a 1/4 inch flat tip screwdriver, push in on the sender assembly attachment tang and lift up on the sender. NOTE: The fuel pump assembly is only serviced as a module without the sender unit. The filter can be cleaned with mineral spirits, however, it cannot be replaced. The fuel pump module to tank O-ring must always be replaced whenever the module is removed from the fuel tank. INSTALLATION 1. Position the sending unit tank in the locator slot and snap the unit into place. 2. Install the two electrical connectors. Pull back on connector without pressing tab to ensure connector is locked. 3. Install fuel pump module, refer to Fuel Tank Unit / Service and Repair . 4. Install fuel tank, refer to Fuel Tank / Service and Repair .
