1993 Saturn Other Repair Question
Topics covered: Engine, Fuel pressure, Fuel pump.
Asked on February 6, 2006
Stalling problem 1993 Saturn SL2
I have a '93 Saturn SL2 DOHC.
The problem I'm havnig is the car will usually start and idle fine, but shortly there after when I come to a stop the tach drops very low, the engine stutters and then will stall.
Ocassionally the car will start and die immediatly unless I hold down the gas pedal.
Car idles fine when cruising.
I Changed the plugs and wires. mechanic tested and changed the serpentine belt tensioner which did not help at all. :(
Anyone have any ideas?
thanks.. al
thanks.. al
Answer
Replied on February 7, 2006
Check fuel pressure for possible replacement of fuel pump/filter.
