Saturn Other
[color=blue][i have a 97 SL2 saturn, 4 cyl, dohc, 140,000 miles, 1.9 L eng.
the fuel pump was replaced and I now have fuel up to the bleeder valve in the engine compartment. However the car will not start, and it appears that no fuel is getting to the plugs. A friend tells me that there is a fuel pump reset button in the trunk. I cannot find one. I also looked under the seats and behind the glove box. I have also checked all the fuses and relays under the hood as well as inside the console. Immediately after I installed the pump, I depressed the bleed valve and the air came out and the car started and ran. The next morning it would not run and it appears the problem may be electrical. No fuel is reaching the fuel rail.
can you give any advice, it would be greatly appreciated.
Robert Messer
hazelbob1@yahoo. Com
July 11, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
