2001 Other Saturn Models Won't sart
2001 SATURN
VENUSENVY
Engine Mechanical problem
2001 Other Saturn Models 6 cyl Two Wheel Drive Manual
Car is a litle low on oil, but started was running and then cut off at a stop light and won't restart. Battery is fine, and will hold a charge.Would not roll off, got the car up to 35 miles an hour and tried to start, still would not start. Wondering if it is the starter or the spark plugs or a combonation of both. Will not even make a cranking noise when attempting to start. Is there an eaiser way to check the starter than having to crawl under the car?
Apr 11, 2008 at 12:19 PM
