2000 Other Saturn Models
2000 SATURN
GEMINI1
2000 Other Saturn Models 4 cyl Front Wheel Drive Automatic 80.000 miles
The car starts and runs good when you first crank it,but when the motor warms up and you stop and turn the engine off it will crank but will not idle correctly or stay running.You have to hold the brake and gas pedal down to get it running,and then it runs good till you have to stop like at a stop sign and it will start the same thing again until you get it moving again.any help would be greatly appreciated.
Jan 9, 2008 at 10:31 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Has it ever been tuned up? Try cleaning the throttle bore around the throttle plate with carb cleaner and a rag. If it continues it could be the Idle Speed Control Motor. Is the check engine light on? If it is have it scanned at Autozone, they do it for free and get back to me with the code/codes
Jan 10, 2008 at 11:17 AM
GEMINI1
Yes i have just had a tuneup and the throttle body cleaned.Any more help would be greatly appreciated.
Jan 10, 2008 at 3:45 PM
2CARPRO JACK
  • 11,533 POSTS
IAC motor as mentioned before, could be sticky or slow to respond
Jan 10, 2008 at 4:23 PM
