Mechanics
MODELS ENGINE RUNNING HOT/COOLANT LEAK DUE
1994 Saturn Other
Engine Cooling problem
1994 Other Saturn Models 4 cyl Two Wheel Drive Automatic 160000 miles
with engine cold and coolant full, I remove expansion tank cap.I start engine an allow to heat-up. When engine heat-up(212deg) coolant will overflow from exp-tank for approx 30 seconds before thermostat wll open and allow collant to flow and fan moter kick on to cool engine. I repaired any leaks, replaced thermost twice I also replaced temp sensor.I am rookie who is tired of guessing. Waterpump , radiator. This car has run great for me without any real problems I could not fix with my limited knowledge.T thankyou for your help THE ROOKIE DO IT YOURSELFER
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
