The best way to change it is to remove the air box then put a floor Jack under the oil pan with a piece of wood between the oil pan and the floor Jack.Use the floor Jack to support the engine then remove the upper mount now Jack up the engine just enough to replace the belt.Then use a wrench to pull back the pressure off the belt and remove the belt.Now reverse order to replace the belt.
May 26, 2010 at 1:20 PM
