2005 Saturn Ion Repair Question
Asked on July 15, 2010
2005 Saturn Ion Acceleration
Shakes or Wobbles problem
2005 Saturn Ion 6 cyl Two Wheel Drive Automatic 71650 miles
My 2005 saturn ion has 71651 miles on it. I was driving on the streets and suddenly my car died, the power was on and the battery light came on, but I still had power. It started right away after too. Now whenever im at a complete stop and I accelerate ill be at 10mph but my rpms is at 3000. Once I hit 15mph the car kicks foward kinda hard and the rpms drops back to 2000. It just started today. When im driving on the freeway and slow down then speed up theres no problem, only when I completely stop. What could it be?
Answer
Replied on July 16, 2010
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
