2CarPros - Car Questions & Answers
1999 SAAB Other Repair Question
Topics covered: Engine, Gas, Spark.
Asked on September 1, 2010
1999 Saab 9-3 Viggen won't start
1999 Saab 9-3 Viggen 4 cyl Front Wheel Drive Manual 122000 miles
I drove my car Sunday, no problems. Monday it started up, went 500ft. then died. I did a rolling start, and after pushing on the gas it died again. After that it woudn't start anymore. The engine turns, but doesn't start, it's not out of gas, and when I turn the engine I can smell gas after a couple of tries. Any ideas as to what the problem is?
Avatar Asked by tapster21
Answer
Replied on September 2, 2010
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Tiny Answered by rasmataz
68 questions asked
