Mazda Protege5 Brake Light Stays On
MAZDA PROTEGE
ME12
Hello. I have a 2002 Mazda Protege5. The emergency break light on the dash comes on at random times while I'm driving and then turns off randomly. Some times it stays on for a long time and other times it's just for a couple of seconds. This happens even if I've not touched the breaks.
Any suggestions?
May 27, 2006 at 1:28 PM
LOSONE
  • CAR REPAIR CONTRIBUTOR
  • 1,616 POSTS
Take the plastic off the emergency brake area, Look for the switch. It could be dirty or loose. It will be easy to tell when you find it by tinkering with it. Good Luck
May 27, 2006 at 4:06 PM
COSMO
  • 347 POSTS
HAve it checked out by your dealer. It is most likely a rear speed sensor failer.
Cosmo...Mazda Tech
May 27, 2006 at 5:22 PM
LOSONE
  • 1,616 POSTS
Cosmo is right. It not a common failure but it does happen. If you sense an odd transmission shift don't wait, go to the dealer. It is a small price to pay to preclude a major failure.
losone
May 28, 2006 at 8:41 AM
