Mechanics
SAAB 900 FOUR WHEEL DRIVE PROBLEM
1984 SAAB 900
1984 Saab 900 4 cyl Four Wheel Drive Manual 100, 00 miles
Fuel leak trickle from under the retaining sleeve on the Black rubber fuel line (not the four raised transparent ones) that go to each cylinder. The Turbo SAAB 900 is fuel injection. Existing line is flexible without visible cuts. The lead seems firmly and tightly clamped to the pipe out from the forward securing nut. Though it is slightly crinkled as from attempts to tighten it more. Is it safe to drive. SAAB here in Kitchener Ontario say there are no longer parts offered, but that by buying and aftermarket rubber tube, gasoline proof and able to with stand the needed pressure, I should be able to replace the existing on. Thanks for any suggestions. Peter
Peter hume
December 8, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
