Mechanics
P1300 TORQUE LIMITATION SIGNAL LOW???
2001 SAAB 9-5
Engine Performance problem
2001 Saab 9-5 4 cyl Two Wheel Drive Automatic 101000 miles
I have a 2001 Saab 9-5 Aero that starts up and idles perfectly. It will also drive fine as long as you baby the gas pedal. However if you go to give it gas, the turbo needle shoots all the way up, the car does NOT accelerate, and the check engine line begins to flash. If you let off of the gas, everything returns to normal as long as you barely press the gas pedal. ODB2 scan tool reveals code p1300-torque limitation signal low?
Jabbys4
July 18, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
