Mechanics
REPLACED ENTIRE COOLING SYSTEM AND STILL OVERHEATS
1994 Toyota Camry • 130,000 miles
I have a 94 toyota camry xle and I changed the entire system. Water pump timing belt thermostat radiator head gasket and hoses. The fan works properly as well and I can't figure it out why it is still over heating when everything is brand new. No leaks or anything. It just gets hot
CHARLESLOPEZ91
May 28, 2013.
When does the overheating occur and under any specific conditions?
Were the cooling fans checked/tested?
Was system bled of air?
Any coolant losses issues?
KHLow2008
May 28, 2013.
The overheating occurs pretty quickly while in IDLE and even faster when drive.
The hydrolic cooling fan was tested and works fine.
The system has been bled of all air and there is no coolant loss at all anymore since I changed all of the cooling system.
I checked the temperture housing and made sure the thermostat was in correctly and everything as well.
I just can't figure out what is making it overheat at all after all this and why it is overheating so quickly as well.
CHARLESLOPEZ91
May 28, 2013.
Is it just the gauge showing hot or coolant is boiling out? Was the actual temperature of the coolant tested when gauge showed overheating?
AD
KHLow2008
May 29, 2013.
AD
