2002 Renault Scenic Repair Question
Topics covered: Air filter, Engine, Gas.
Asked on January 1, 2009
2002 Renault Scenic air filter
Engine Performance problem
2002 Renault Scenic 4 cyl Front Wheel Drive Manual 50000 miles
how do i change the air filter, how does the air filter compartment open ?.
Answer
Replied on March 15, 2009
there is either 3 screws or 3 flip over clips holding the top in place ?
Replied on September 2, 2009
Hello there my friend..Usually the Air Filters can be found in the large plastic box under the bonnet with a large air pipe leading from it to the engine. Just undo the catches to open the box, remove the old air filter, put the new one in and close the box back up again. Then you are done with it.
