1999 Renault Megane
Engine Mechanical problem
1999 Renault Megane 4 cyl Two Wheel Drive Manual 79000 miles
head gasket gone
got the gasket skimmed replaced ran for 5 mins then stoped
replaced again this time with new head bolts it ran ok 5 mins again it stoped
is it possible that the coolant leaked and damaged the lmbada sensor?
i am going to get the mechanic to replace this anyhow but could there be anything else wrong?
dont want to spend too much more money as I think the mechanic is just clutching at straws
December 15, 2008.
Is the MIL on the dash coming on? If so have the codes read. If any sensors are at fault the cars computer will tell you? The sensor would not make the car stop running. Could you explain in more detail what is happening?
Dave H
Dec 15, 2008.
