Mechanics
CENRAL LOCKING
2004 Renault Laguna
2004 Renault Laguna Two Wheel Drive Manual 55000 miles
i own a 2004 renault laguna extreme and I have a slight problem every and again when I lock the car via the key card, all the doors lock apart from the driver door which I have to lock by turning the screw in the drivers door?Is there a easy way to resolve this
STEVEN19
June 26, 2009.
Hello .. thanks for the donation .. much appreciated
You will need to check the wiring to the lock motor from the PCM (computer) sounds like the feed wire is damaged/corroded/loose/worn and only getting a connection intermitently ??
hope this helps
http://www.2carpros.com/forum/automotive_pictures/266999_AAA2_824.png
Dave H
Jun 27, 2009.
