Engine power reduced p2138
2008 SATURN AURA
115,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
BADDAWG
My check engine light came on and I ran the codes - engine power reduced p2138?
Feb 9, 2014 at 5:15 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
This happens when the car goes into limp mode due to the throttle bore being dirty. Here is a guide to help you fix the problems.
https://www.2carpros.com/articles/reduced-power-limp-mode
Feb 9, 2014 at 7:16 PM
MSFONDAY
what would cause reduced engine power read out?
Feb 19, 2019 at 6:28 PM (Merged)
PROTECH1980
  • 901 POSTS
You are going to have to get the vehicle scanned to retrieve the trouble codes that are stored in the computer, that will be the starting point for diagnoses.
MSFONDAY
the scan was negative
WATT
Left key in car in the on position. Drained the batter. When I boosted it off the reduced power light came on. When I turned it of after running for a while it still did not crank. I boosted again with the same problem. Help
SATURNTECH9
  • 30,869 POSTS
So have you had the battery and alternator tested yet?
SUEMASUGA
happened in 1 sec. started the car up and all the warning lights came on, what causes this?
SATURNTECH9
  • 30,869 POSTS
You need to get your car scanned for codes let me know the exact code numbers not code descriptions you have.Sounds like an issue with the throttle by wire system.
SHANNON_PRIV
Thank you for this post I had this problem cleaning the throttle bore fixed it :) I love this site.
Feb 19, 2019 at 6:29 PM
