Mechanics
REAR A/C BLOWS HOT AIR.
1995 GMC Sierra • 255,000 miles
My ac had a leak in the fill valve, and over the winter the freon all went away.
I replaced the valve and added freon to it, and the front unit started working well.
When I checked the REAR unit, it was blowing HOT air. Not WARM, but HOT !
Even the condenser coil was hot to the touch.
About that time, the front blower died too.
I replaced that, and the front unit still works well, but I need to know what to check on the rear unit.
Suggestions?
Thanks,
Rick
RickInTexas
May 18, 2013.
The condenser is supposed to be hot
what were the exact pressures?
Did you replace the dryer and orfice tubes? Evacuate the system before charging?
What did you replace? The front blower motor?
ASEMaster6371
May 18, 2013.
