Mechanics
WENT INTO HIGH IDLE AND HARD TO START
1996 Ford F-150 • 190,000 miles
Put in new fuel filter and new fuel press. Reg truck went into high idle and hard to start will etc make it do this put in new fuel filter and new fuel press. Switch on the rail truck ran good for 2 mi. Went into high idle and hard to start also stepping on gas truck try to die truck would not start with out running the starter a long time turn the switch on 5 time then it will start
Dlharmansr
June 16, 2013.
Check the fuel pressure sounds like a bad pump
Hmac300
Jun 16, 2013.
AD
