Mechanics
POOR ACCELERATION WHEN FIRST STARTING 1.6 ZETEC AUTOMATIC
2002 Ford Focus • 75,000 miles
For the last month, my car has had absolutely no power when it first starts up - if I put my foot on the accelerator it 'phuts along at 5-10 m.P.H. - Making occasional 'popping' noises.
If I sit for about 10 minutes with the engine running, it will marginally improve, though if I put my foot down too hard on the accelerator, the engine screams in protest. If I take it out of 'drive' and put it down to 2nd, it sounds as though I'm changing up (if it was a manual, I guess).
After about a mile or so, it will pick up a bit and I can put it in to drive again, though if I stop at a junction, it is dangerously sluggish as I pull away.
It occasionally behaves sluggishly when I am overtaking and occasionally screams in protest if I put my put down for the same reason.
I know it's an old car but it had a new engine fitted in 2006, so am hoping it's not something major. My mechanic has tried to fix it but is now at a loss to know what is wrong.
Kmaffey
September 30, 2013.
Scan for codes and check fuel pressure first. Check intake vacuum if 15" or below suspect clogged converter.
Hmac300
Oct 1, 2013.
AD
