2CarPros - Car Questions & Answers
2004 Pontiac Vibe Repair Question
Topics covered: Wheel.
Asked on August 21, 2010
2004 Pontiac Vibe Tail Light Assembly
2004 Pontiac Vibe 4 cyl Front Wheel Drive Automatic 117000 miles
I need to replace the driver side rear tail light assembly as the current one has been cracked. Have ordered a replacement from local salvage yard. How do you remove the old one? I cannot locate the screws. After opening the hatch there appears to be a plastic piece that the screws may be under. Do I need to pry up that plastic to get at the screws. Not sure if the plastic is attached attached to the tail light cover. Any advice on lifting that plastic without cracking it?
Avatar Asked by jm19592001
No Answer Yet
