Mechanics
RIGHT SIDE POWER WINDOW
1997 Pontiac Transport
Window first would not go up, so I took door panel off, and was able to close window. Checked wires and have voltage. Then window would power up, but not down. Took out motor and tried another with same results. Tested motor on bench by attaching 12 volts to each side of wire plug. Motor worked OK. On your forum, someone else seemed to have same problem. You suggested changing the " BODY CONTROL MODULE". What is the location of that module? Thanks Ken
Ken Cameron
February 13, 2006.
Please post in the correct forum
Thanx
Jack42
Feb 14, 2006.
