1999 Pontiac Trans Am Repair Question
Asked on November 18, 2009
1999 Pontiac Trans Am Clutch
Transmission problem
1999 Pontiac Trans Am V8 Two Wheel Drive Manual 92,000 miles
To my understanding, I have to remove the master from the firewall, unbolt the trans from the block, leaving the flywheel and clutch in place, access the bleeder valve, have someone depress the clutch slowly, while I open the valve? Is it necessary to to have the master lower than the sc, when bleeding? I don't have to remove the hydraulic line from it, if I'm only gonna bleed it right? I just want to do this one time and do it right so I'm asking if this is the correct procedure. I'm very grateful for your advice.
