2006 Pontiac Torrent Repair Question
Topics covered: Coolant, All wheel drive, Engine.
Asked on August 12, 2010
2006 Pontiac Torrent 2006 Pontiac torrent overheating issue
Engine Cooling problem
2006 Pontiac Torrent 6 cyl All Wheel Drive Automatic 80000 miles
Hi there, my 2006 Pontiac torrent its overheating as well, did you ever found the problem?, in my case both of the fans are working properly, I have replaced the thermostat and water pump, but the problem its coming back again, the fluids levels are ok.
On other forums Ive read about a gasket issue that makes the coolant to leak inside the cylinder chamber, here Lady_Chaos says about a bad coolant sensor, others says about bad headers.
It has 80,000 miles on it.
