1991 Pontiac Sunbird
Electrical problem
1991 Pontiac Sunbird 4 cyl Two Wheel Drive Automatic
Hello. I recently stopped at a stop sign and my car gave a chug and died. I have determined that it is an ignition problem. The distributor is not getting a spark( I tested that with one of those dummy spark plug testers.) I have just put a new coil on and still I have no spark being generated. I have also tested out all the relay switches in the car and found that they are still good. The distributor does turn so it cant be a timing belt issue? Just no spark. I am at a loss as to what else the problem could be. Something inside the distributor maybe not generating enough power to get a spark out of the coil? All the wires seem to be in good order and there is power going into the coil.(Used a tester light). I am going to take back the coil and get a replacement cause as we all know, just because its new doesnt mean it works properly. But as you can tell I am at a lost as to what else it could be. Anything you guys have to offer would be very much appreciated.
Thank you
August 25, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
