Mechanics
COOLANT REPLACEMENT
2002 Pontiac Grand Prix
Engine Cooling problem
2002 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic 107000 miles
I have to replace coolant in my car every 3 days. The temperture gauge doesn't indicate that it's hot, there are no leaks. Could this be a thermostat or water pump problem?
Reliford
August 6, 2009.
It is either leaking it or burning it, is it blowing puffs of white smoke out exhaust?
First perform a compression test, if OK, then pressure test the cooling system.
If compression test shows 1 or 2 low readings, the do not perform cooling system test, you have a bad headgasket, intake gasket.
Mmprince4000
Aug 8, 2009.
AD
