Pontiac Grand Am Repair Question
Topics covered: Fuse, Fuel pump, Fuel pressure.
Asked on February 22, 2007
No fire
1987 pontiac grand am v4 2.5L. i have tried everything i can think of. my car wont get any fire i changed the coils coil housing crank sesor and the computer and even checked all the fuses. please help
Answer
Replied on February 22, 2007
did you replace the dis module (under coil) and do you have fuel pressure
Replied on February 23, 2007
yes i replaced the dis but i cant hear the fuel pump kick on when i turn the key over.
check the fuel pump relay and fuse and let me know what you get
relay is all new and fuses are fine.
ok nest place to check is at the pump , pull the harness and use a test light and aperson to turn the key off and on , probe the connector and turn the key on look for 2 seconds of power at the pump , you may have to do this a couple of times , check that and we will go from there
me and my dad replaced all of that too.
has anyone checked the power out of the ignition switch???
