We then did the recommended procedure of making the car level, and taking out the drain plug. We added a little fluid until in drained out of the hole -- so the fluid level was at the bottom of the hole. (We didn't add much, we were pretty close with the first calculation.) The car still shifts hard. Then we added a little more fluid (maybe 3 ounces), and the car still shifts hard.
We want to know if we have too much fluid or too little -- or should we put in some additive? The car was shifting fine before, and this wasn't a big deal to change the fluid and filter. We want to know if we should take fluid out? Add more? What direction do we need to go in? Thanks!
It is a 3.4 L V6 with 80,000 miles on it.
SPONSORED LINKS
Sunday, August 5th, 2007 AT 1:30 PM
