How to replace thermostat in a 06 Pontiac G6 3.5L?
ALEXWALLUM
  • 2006 PONTIAC G6
  • 232,000 MILES
I need step by step and possibly pictures or a diagram of some sort?
Saturday, November 5th, 2011 AT 3:15 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Here is a guide that will show you what you are in for when doing the job along with a diagram (below) of what it will be like on your car.
Here is the instruction from the book
THERMOSTAT HOUSING REPLACEMENT (3.5L )
Removal Procedure
Fig. 114: Thermostat & Housing Outlet
Courtesy of GENERAL MOTORS CORP.
1. Drain the cooling system. Refer to Draining and Filling Cooling System.
2. Remove the air cleaner outlet duct. Refer to Air Cleaner Intake Duct Replacement for the 3.5L engine.
3. Disconnect the surge tank hose from the coolant outlet.
4. Remove the thermostat housing to intake manifold bolts.
5. Remove the thermostat housing outlet and thermostat.
Installation Procedure
Fig. 115: Thermostat & Housing Outlet
NOTE: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring
replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants or
corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may
damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
1. Install the thermostat and housing outlet.
NOTE: Refer to FASTENER NOTICE .
2. Install the thermostat housing bolts.
Cheers, Ken
Tuesday, October 3rd, 2017 AT 9:15 PM
RICHANGLER
  • 2006 PONTIAC G6
  • 6 CYL
  • FWD
How do I change thermostat on 2006 Pontiac G6 six cylinder?
Tuesday, October 3rd, 2017 AT 9:16 PM (Merged)
HMAC300
  • 48,601 POSTS
It depends on which one you have the 3.5L is on the end of the inlet manifold and the 3.9 is on the side by the water pump. Both have hoses going to them. You need to drain the cooling system down, remove the hose from the housings, remove the bolts and remove the thermostat. REverse teh procedure for installation. Torque bolts to 25nm or 18 ' lbs.
ELEEVAL
  • 2005 PONTIAC G6
  • 138,700 MILES
I need to replace the thermostat.
JIS001
  • 3,408 POSTS
Remove the air cleaner housing and then remove house. Remove the bolts and to remove thermostat housing. When you fill, open bleeder valve on housing until coolant comes out. Re-tighten and warm up engine and open bleeder slowly until all air is out. Good luck.
HOOAH_90
  • 2007 PONTIAC G6
  • 6 CYL
  • 58,000 MILES
I just had my 2007 pontiac g6 v6 in the shop. The thermostat gauge was stuck, wasnt rising as I was driving. It just stayed at 100. The check engine light was on aslo. The mechanic replace the thermostat and it was ok for 1 day. Well the gauge dropped back down to 100 and the light came back on. My heater is working. Not as strong as it use to. What should I do? Take it back and trust the mechanic or take it to a dealership.
Also, Is it safe to drive or do you see a major problem with me driving it?
WRENCHTECH
  • 20,757 POSTS
It sounds like it may have a defective thermostat but I would take it back to the guy that installed it so he can at least check for a problem. You might want to insist that he use OEM parts next time.
JSB429
  • 2007 PONTIAC G6
  • 6 CYL
  • AWD
  • 62,000 MILES
Engine Performance problem
2007 Pontiac G6 6 cyl All Wheel Drive Automatic 62000 miles
how do I replace my thermostat on my 2007 pontic g6
SATURNTECH9
  • 30,870 POSTS
Do you have a 3.5 3.6 or 3.9L engine?Let me know so I can get you the correct information.
RAMIROH
  • 2007 PONTIAC G6
  • 6 CYL
  • FWD
  • 88,000 MILES
Where is the thermostat on a pontiac G6
2007 3.5
Tuesday, October 3rd, 2017 AT 9:17 PM (Merged)
PROTECH1980
  • 901 POSTS
As your standing looking at engine follow radiator hose on your right from radiator to t stat housing.
GMTECH
  • 537 POSTS
Why is the engine light coming on. Usually wherever you go will have a package deal for the flush. 60 to 100 and depending on the price of the thermostat another 50 to 100 bucks
