Try the key first and check all fuses. If the latch is broken then you will need to unbolt it from the inside this means you must remove the rear seat and crawl in to access the latch.
Best, Ken
SPONSORED LINKS
Saturday, April 1st, 2017 AT 6:06 PM
DAVID
MEMBER
1 POST
2007 PONTIAC G6
6 CYL
2WD
AUTOMATIC
25,000 MILES
Electrical problem
2007 Pontiac G6 6 cyl Two Wheel Drive Automatic 25000 miles
checked 22 and 23 in fuse box -- both good, nothing is listed for tunk ----where shoukd I go from here
Saturday, April 1st, 2017 AT 6:09 PM
(Merged)
MECHANIC
Have you checked to see if you are getting power to the actuator in the trunk? It may be bad.
